Replaced the screen and battery now momentarily screen goes black
Last Sunday I replaced both the screen and battery for my iphone from parts from here. Today, twice while using the my phone the screen goes black and won't open then comes back on to the lock screen. The last time this happened I was listening the podcast in the store. The screen went dark I heard my bluetooth earbud disconnect, before it returned to the lack screen.
Score
0
When it goes dark, is it rebooting - as in, you see the Apple logo first, then after a bit it returns to the lock screen?
by Jerry Wheeler
No, no apple logo. Just straight to my lock screensaver
by CyanSable
Actually the first time it happened today, heard a notification, the screen went black and wouldn't open, then I went to turn it back on. Should I reopen the screen and make sure all the connections are correct? I'm already gonna open it to reapply the a new adhesive layer. One area i messed up applying it, so it stands up a tad, but hasn't been around any sort of moisture to worry about
by CyanSable
@cyansable Definitely worth your time to recheck your work. Disconnect any plugs you originally did for your screen + battery replacements and check both sides with a magnifying glass looking for any bent or missing pins. Assuming everything looks good, clean all the connectors with 90% or higher concentration isopropyl (rubbing) alcohol. Give them a moment to dry, then carefully reconnect everything and retest before gluing the screen back down.
by Jerry Wheeler
Could be a issue with being aftermarket parts. Ie, no Apple serial numbers.
by Ted
Show 3 more comments
