Released in 2003, the iBook G4 replaced the iBook G3 as Apple's portable consumer computer.
715 Questions View all
Can`t load iLife `09 DVD..
I`m using a Lacie DL DVD drive as neither of the above has a working internal optical drive. iLife `09 won`t mount on the desktop of either computer though it will on the iMac G5 we have here..(It`s a new family pack). I`ve tried making a disk image of iLife on the iMac in disk utility & transferring it directly to one of my external HD`s but it says the disc is too big....Would buying a new internal drive for one of these G4`s & installing be any help...( the drive in the Lacie DL DVD burner mentioned was recently replaced & works OK for anything else) The G4`s have the right specs according to what`s required on the slip in the iLife box..?
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Chosen Solution
Start the receiving Mac up in target mode, via firewire. Use the G5 as the main computer. Drag the install icon from the DVD to the external hard drive. Now it's in place and will install if the machine specs are correct.
Score 1
Comments:
Target disk mode to the rescue! It's one of the features of a Mac that I love so much, yet it's also the one I rarely remember.
by
I`ve used target mode before but wasn`t quite sure of the modus operandi this time! The G5 isn`t my computer so it might take a while to get on it.. Thanks!
by
Add a comment
Most Helpful Answer
What OS are you using on the G4's. From what I read iLife 09 requires OS 10.5.6 to run. Ralph
Score 1
Comments:
I know you say you have the right specs but wanted to be sure of the OS. Ralph
by
Both computers have Mac OS X 10.5.8..thanks for you interest!
by
Add a comment
Add your answer
mgaffney will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,084
