好的,所以需要夹子来把东西固定在一起。这告诉我,显示器要么被剥到外壳体上,要么显示器本身就失效了。通常,这是电池从内部按压的故障迹象,因为里面的气体使电池充气,导致电池起泡。
考虑到你的年龄和玩游戏的用途,可能是时候买一块新电池了iPad Pro 11" (2018) Battery,这是把它放在(英语)iPad Pro 11" 1st Gen Battery Replacement,你可能想找人帮你阅读指南,因为我认为我们没有中文书面指南。
无论如何,在修复显示屏组件的安装之前,您需要处理它,因为当电池发热时,由于电池内部的压力(通常是游戏外壳),触摸传感器可能会起作用,导致电池的电解质释放出更多的气体。当iPad没有被使用时,压力会降低,并且通常可以在那时完成简单的使用。
至少检查电池是否有起泡或更换后,您可以重新安装显示屏组件并丢弃夹子。希望显示屏的触摸表面不会因事件而损坏。这可能会
OK, so the clip is needed to hold things together then. That tells me the display has become either unglued to the shell body or the display it's self is failing. Often times this is a sign of a failing battery pressing from within as the gases within are inflating the battery causing it to blister.
Given the age and your use playing games on it its likely time for a new battery iPad Pro 11" (2018) Battery and here's the guide to put it in (English) iPad Pro 11" 1st Gen Battery Replacement you may want to find someone to help you read the guide as I don't think we have a Chinese written guide.
In any case you will need to deal with that before you can fix the mounting of the display assembly as the touch sensor can act up due to the pressure from the battery from inside when running hard (often the case with gaming) as the battery heats up causing more gas to be released from the electrolyte of the battery. When the iPad is not been used the pressure reduces and simple usage at that point can often be done.
One the battery is at least checked for blistering or replaced you can then remount the display assembly and dispose of the clip. Hopefully the displays touch surface is not damaged from the event. This might re
6 Comments
如果您将 iPad 从保护壳中取出,并在片段或其他物体不接触屏幕区域的情况下重复操作,会发生什么?
What happens when you remove the iPad from the case and repeat the action with out the clip or other object touching the screen area?
by DanJ
@danj 钢化膜保护壳取了都一样 充电器用的都是苹果认证的安克
by hhhh
会不会是正好夹子下面的排线问题
by hhhh
@hhhh70073 - 你能更好地解释一下这个问题吗?我以为那个夹子是你放在iPad上的绿色夹子。
“钢化薄膜保护壳是一样的。这些充电器都是 Apple 认证的 Anke。”
“这可能只是夹子下面的线条问题吗?”
屏幕的触摸灵敏度有问题吗?不明白你为什么不带充电器进来。iPad 无法充电吗?
Can you please explain the problem a bit better. The clip I thought was the Green clip you have placed on the iPad.
"The tempered film protective case is the same. The chargers are all Apple-certified Anke."
"Could it be that it's just the line problem under the clip?"
Are you having issue with the touch sensitivity of the screen? Not following why you are not bringing in the Charger. Is the iPad not charging?
by DanJ
@danj 充电没问题的 触摸滑动软件都是正常的只是打游戏很容易断触偶尔正常用屏幕会乱触打游戏特严重 其他的乱触是间断性的
by hhhh
Show 1 more comment
