@blank9899 not sure if yours is a RHD or LHD. On a LHD car the indiator relay is on the component panel to the left of the steering column. Above and to the left of the main fuse box.
A Fusebox Panel, driver side
B Fusebox panel, passenger side
1 Motor/solenoid, door lock
2 Motor, window winder
3 Door speaker
4 Cruise control, main switch
5 Bulb failure unit
6 Relay, heated rear window
7 Relay, ignition protection
8 Relay, direction indicator
9 Fusebox, main
10 Bulb failure unit
11 Device, low coolant warning
12 Protection switch, door locks
13 Delay unit, wiper motor
14 Fusebox, auxilary
15 Protection switch, power windows
16 Protection switch, power windows
17 Bulb failure unit
18 Vacuum delay unit
19 Relay. power windows
20 Switch, power mirrors
21 Motor, power seat height adjustment
22 Switch, power mirrors
23 Relay, power locking
Replace that relay and let us know what the result is :-)
4 Comments
I just replaced the turn signal relay /direction indicators relay and the turn signals and hazards still are not working
by Blank
You’re going to have to get the multimeter out and check for breaks in the cables. When you turn the indicators on can you here the relay clicking? You might have to remove the fuse/relay board and check for broken traces and cracked solder too.
by Ted
I messed around with the relay and fuses now they are working for the most part all of the turn signals work besides for the back left one and the Hazzards still arent working. Working on getting a multi meter to check the cables but if there's anything else it might be I'd be glad for the help.
by Blank
Check for bad earth points. If any look corroded give them a clean. With an old car it could well be part of the problem.
by Nige56
