The TH (turbo-hydramatic) 700R4 was developed for use after 1982 in GMC and Chevrolet cars and trucks.
34 Questions View all
Why won't my 700r4 downshift?
t.v. cable adjusted properly, spool valve works, and governer is fine but when applying throttle car will not downshift. converter will unlock but no downshift. when slowing to a stop trans downshifts though slightly delayed. trans wasn't overheated and has less than 8000 miles.
Add a comment
Chosen Solution
I think it might be a stuck downshift valve.
Check out this long discussion about it and see if you can find anything that helps you.
Good Luck
Add a comment
Could be the shift solenoid or the speed sensors chech them is also possible the sence it sat for so long that the filter is just pluged up
Add a comment
Add your answer
matt will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 119
All Time: 5,420
