Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
411 Questions View all
Swapped with Mid 2009 Display/Sleep Sensor
I have the late 2008 early 2009 MBP Unibody 15" with the removable battery.
I recently swapped out the LCD assembly with the mid 2009 LCD assembly.
I later discovered that the mid 2009 LCD has the sleep sensor magnet on the left side of the screen rather than on the right side.
I want to avoid peeling the glass display off and moving the magnet to the other side.
My question is, is there a way where I can re-route the sleep sensor, located on the right side, to the left side where the USB/Mini Display connections are at?
Comments:
I checked it out and there isn't enough of the wire strip to be routed to the otherside; on top of that it's linked to the infrared.
Do you know if the the mid 2009 sensor will work with this series and how would I go about in rigging it?
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
You seem to be pretty good at fixing things. Go for it. Just open it up and splice enough wire in to run it to the other side. Use light weight electrical tape on the splices and do not cross the motherboard with the wire. Tape he sensor in place.
Score 1
Comments:
Hi Mayer,
Could you repost that link
thanks
by
Add a comment
I also have the same problem. I just put in a new display assembly, only to discover that my MacBook Pro unibody does not react, when I open/close the lid. Maybe I can use a part from the old assembly. Where are the magnets located?
Would it work?
Comments:
You need to start your own question
by
The magnets are located along the top left/right edges of the screen and if you have the new screen from the 7 hour unibody, the magnet that activates the sleep sensor is located along the middle edge of the left side of the screen.
by
Add a comment
Anyone as a detailed procedure? with picture of this procedure?
I have the exacte opposite early 2009 with 2008 display magnet is reverse.
MBP 15
Add a comment
Add your answer
linuxduckie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 3,565
