Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3237 Questions View all
iPhone 4S Camera in iPhone 4?
Hello,
today i got this weird idea, it is possible to pick the 4S camera and put it in an iPhone 4?
I know that the cables aren't compatible so you also need an A5 chip, don't you?
Comments:
oh man :/
but anyway thanks for you responses.
I think i'm going to save my money for the next generation iPhone :)
by
Marc, sounds like a great idea:-)
by
Add a comment
Chosen Solution
this might help
http://www.beijingiphonerepair.com/hack/...
Comments:
thanks that really helped, so its a kinda possible but i dont think we cannot aspect any camera driver update.
I really want that! :)
by
but theoretically you can plant an A5 in there and then it should work?
by
@ Marc...No, not even in theory.
by
Add a comment
Most Helpful Answer
Marc, the connector on the logic board is different. It is not your IC that needs to be replaced but your connector, as well as the logic board itself, that will make the difference. The answer is no, you can not. Read the answer to this question iPhone 4s camera in iPhone 4? and the explanation right here Will the iPhone 4S camera module work in an iPhone 4? and many more. Just do a search on here and you will get confirmation on that. Hope this helps, good luck.
Score 2
Add a comment
Add your answer
Marc will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 2,241
