iPad Pro 11 gen 1 doesn't charge above 1%
Hi everyone!
I have a problem with my iPad,
the device is already quite old, bought in November 2018.
It has 755 battery cycles.
The program coconoutBattery shows that its maximum capacity is 118mah at 7800mah.
When I plug it in to charge (original cable and Apple charger) the device does not charge above 1% and reboots itself after a minute.
I have already tried resintalation of the software using the 3uTools tool with the option to clear battery memory checked.
Unfortunately, this doesn't help anything.
In DFU and Recovery Mode the device does not turn off or restart (it is plugged into the charger).
Is it possible to determine that the problem is the old battery? I would like to order a new one and replace it. Just wondering if this is not a different problem.
The device is not damaged, it has never fallen down.
Thank you for your help.
Add a comment
