15% Off Selected iFixit Tools — Limited Time
Repair guides and support for the fifth-generation Century, a series of front-wheel drive coupes and sedans manufactured by Buick.
How can I connect my starting motor
Bought my first car but came with the cables uninstalled, it's year 89 and I don't know why but I think I'm doing it wrong because the starter just sounds but the Bendix doesn't come out
Score 1
Add a comment
1 Answer
Chosen Solution
If your 1989 Buick Century’s starter motor spins but the Bendix gear (the part that engages the flywheel) doesn’t pop out, you're likely facing one or more of the following issues—especially since the starter cables were disconnected when you got the car.
Let’s go step by step:
✅ First: Basic Starter Wiring (for 1982–1996 Buick Century 2.5L & 3.3L engines)
Your starter motor has two or three terminals:
  1. B (Battery terminal) — large stud for thick cable directly from the battery (+)
  2. S (Solenoid signal terminal) — smaller terminal, gets 12V from the ignition switch when you turn the key
  3. (Sometimes) R terminal — not always used; originally sent power to the coil during cranking on older systems
Correct wiring:
  • Thick battery cable (positive) from the battery goes to the B terminal (large post).
  • A smaller wire (usually purple) goes from the ignition switch to the S terminal.
  • The starter must be grounded through its mounting bolts to the engine block.
📌 Make sure the ground strap from engine to chassis is intact!
🔧 Now: Why the starter spins but doesn’t engage (Bendix issue)
If your wiring is correct and:
  • You hear the starter spinning, but it doesn’t crank the engine → the Bendix gear isn't engaging the flywheel.
Possible Causes:
  1. Low battery voltage
    • 🔋 Starter might spin but solenoid doesn't have enough juice to push the Bendix out.
    • ✅ Try jump-starting it or use a multimeter: make sure battery is at 12.6V+.
  2. Weak or broken solenoid
    • Solenoid is the part that pushes the Bendix gear out.
    • If it clicks or buzzes but doesn't move the gear → it's likely bad or sticky.
    • 🔧 Try tapping the starter lightly with a hammer while someone turns the key.
  3. Incorrect wiring
    • If the small wire is on the wrong terminal, the solenoid might never get signal.
    • ✅ Double-check the small wire goes to S terminal.
  4. Bad starter (even if new or rebuilt)
    • If it was sitting for a while or is used, the Bendix can get jammed.
    • May need disassembly and cleaning or complete replacement.
🧪 Test trick (if safe to do):
  • Turn ignition key to ON (not START).
  • Use a screwdriver or remote starter to short the large post (battery) to the S terminal on the starter.
    • If the Bendix kicks out and turns engine = ignition circuit may be at fault.
    • If it still doesn’t engage the flywheel = starter itself is likely bad.
🔄 Final checklist
Component Check Battery voltage 12.6V+ at rest Starter wiring Big cable to large post, purple wire to S terminal Engine ground strap Tight, clean contact Starter mounting Bolted firmly to engine Solenoid action Clicking and pushing Bendix gear forward Flywheel Not damaged or missing teeth (remove starter to see)
Score 1
Add a comment
Add your answer
Abrahan Huen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 36
All Time: 214
