Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1409 Questions View all
My backlight isn't working! Inverter cable seems fine, now what?
Intel Macbook from 2008,
OSX 10.6.8 if that helps.
My macbook's backlight recently went out. Last time I had this issue(when I was on 10.5.8), it would flicker on and sometimes stay on for half an hour or so, and the mac store told me it was due to a faulty update. This time around, I was taking it apart anyway to replace a clutch hinge, and noticed there's a frayed white cable on the bottom right hand side of the top casing.... I'm pretty sure this has something to do with the screen, and seeing as how I don't have applecare anymore, I probably need to fix myself. Anyone know how?
Edit: Mayer's guide had a picture with the cable in it, here it is circled. http://i176.photobucket.com/albums/w190/...
Comments:
Er.... top half of the casing, as in, behind the screen. Just making sure I don't sound like I mean near the trackpad.
by
Please give us the last three figures of your serial number so we know your exact machine.
by
Last three of serial are 0P1
by
Apple MacBook "Core 2 Duo" 2.4 13" (White-08) Specs
Identifiers: Early 2008 - MB403LL/A - MacBook4,1 - A1181 - 2242
by
Add a comment
Chosen Solution
See if the pink and yellow wires of this guide look like yours: MacBook Core 2 Duo LCD & Inverter A1181 (fast method) Replacement
Score 3
Comments:
Also look through this guide for your wires: MacBook Core 2 Duo Inverter Cable Replacement
by
Add a comment
Mayer idea is right. Usually, the culprits for a bad backlight are three. Well, four, but the latter one is so rare to be utterly nonexistant.
1. A damaged inverter is the first one, and it's usually responsible for an absent, or dim backlight.
2. The second culprit is the inverter cable. You must however notice that a damaged or frayed inverter cable may look fine, but actually may be internally damaged, bent or broken. The telltale symptom is a blinking backlight, that goes on and off when you jiggle the monitor, until it's utterly trashed, and then it gives an absent backlight.
3. The third cause is a faulty CCFL lamp. A CCFL lamp is... picture it a small neon, lodged on the back of your LCD. When it's aging, it starts to give off a yellowish or pinkish hue, until the light dies.
The fourth cause, negligibile and never observed by myself, is a bad capacitor near the Inverter Cable.
You found a frayed white cable however. Check with mayer's guide: there's a possibility it's one of the cables soldered to the CCFL lamp that connect to the Inverter.
I suggest you to try to fix the cable ASAP: I wouldn't keep a frayed cable near a hinge. However, if it's the white cable that comes out the LCD panel, as mayer instructed you, you may have in your hands a mild case of case 3: your CCFL lamp is fine, but its connection to the Inverter is busted.
I doubt you fried the CCFL lamp, but since you're at it, you may fix the cable.
Score 2
Add a comment
Add your answer
Kate will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,074
