The 4th generation Surface Laptop, released in April of 2021, shares the same body design as its predecessor, with upgraded internals including Intel 11th gen and AMD Ryzen 4000 processors, more RAM, and upgradeable SSD storage.
Does a laptop 3 lcd display fit into a laptop 4
I want to repair my microsoft surface laptop 4 13.5 inch display, but i have original part microsoft surface laptop 3 13.5 inch
Add a comment
1 Answer
Yes, the 13.5" screen from a Surface Laptop 3 is compatible with the Surface Laptop 4. Same size, resolution, connectors, and mounting points — it should work just fine.
The only small difference might be the panel manufacturer (LG, Sharp, etc.), so you might notice slight differences in color or brightness, but nothing major.
Just be careful when opening the device — Surface Laptops are glued shut and can be tricky to disassemble without the right tools.
Add a comment
Add your answer
Ikshan Aditia will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 21
All Time: 127
