Repair and disassembly information for Sony WH-1000XM3 wireless noise-cancelling over-ear headphones.
Can I swap the battery from one WH-1000XM3 to another.
I have a WH-1000XM3 that won't turn on, or respond to the reset process and I have a second WH-1000XM3 which works. Can I swap the battery from the good headphones to the faulty headphones to determine if the battery is the fault, or would this cause a safety risk? The battery replacement guide on this forum warns against re-use of a removed battery.
Add a comment
1 Answer
its fine to remove it and try it in the other set
Add a comment
Add your answer
Darren Hancock will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 87
