Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Questions View all
Why it vibrates when I tap it?
When I tap my iphone with my finger near to the vibrator (left from the home bottom) I feal a little vibration on my hand without hearing some noise. Is this normal or I have trouble?
Score -1
2 Comments
Well - not sure if it's normal but mine does the same thing.
by
Yes, Mine does the same when I Tap it at lower side, near the Home Button...
any Fixes...?
by
Add a comment
Chosen Solution
Well the vibration motor sits under the lower left side of the motherboard on the back....So it would be the lower right side on the front of the phone. If there is a screw out of place or the contacts are not straight and aligned with the contacts on the bottom of the motherboard it may cause that. If its been apart, try pulling the motherboard back out and make sure the vibration motor is straight and the contacts align properly with the two pads on the bottom of the motherboard.
Hope this helps!
Score 1
Add a comment
Most Helpful Answer
Mine does the same thing.
I fixed by not tapping it anymore.
Score 1
1 Comment:
+great answer ;-)
by
Add a comment
Add your answer
micro4 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,421
