Samsung Galaxy A13 (SM-A136U) Power Button Replacement
I need to replace the power button on my Samsung Galaxy A13 (model SM-A136U), but I can't find a specific guide or a replacement power button part on iFixit. The button is not working. Has anyone else had this issue or know if the power button is part of another component? Any advice on how to proceed with this repair would be greatly appreciated.
I had to replace mine and after dropping the phone a few times had issues with it again. Take Sim card slot out and open carefully (ribbon cable is attached from button to board). Take out screws of top plastic piece and gently pry up the clips on side. There is a little metal piece that sits over where the ribbon cable attaches to the board. I have had to pull that out and slightly bend it inwards because the cable wasn't making good connection after dropping it a couple of times. After I did that it worked fine for quite a while. I still have to replace the power button again though because it finally failed. Hop this helps.
by Joe Welch
