You've hit a classic and frustrating problem with Wii optical drives, especially concerning dual-layer discs after a replacement. Let's break down what's likely happening and your options.
Understanding the Problem: Dual-Layer Discs and the Wii
The key takeaway here is that your Wii is reading single-layer GameCube and Wii discs perfectly fine, but failing specifically on dual-layer Wii discs (like Metroid Prime 3: Corruption, Super Smash Bros. Brawl, Metroid: Other M, Xenoblade Chronicles, etc.).
This behavior is a very strong indicator of a calibration issue with the laser lens, specifically for the second layer of the dual-layer discs.
Why a Replacement Drive Might Not Solve It (Initially):
Even "new" replacement DVD drives or laser lenses for the Wii can suffer from this problem for a few reasons:
- Factory Calibration Varies: Not every new laser lens or drive comes perfectly calibrated for every console. There's a tiny potentiometer (a variable resistor) on the laser assembly that controls the laser's power output. This needs to be precisely adjusted for optimal reading of both single and dual-layer discs.
- Manufacturing Tolerances: Slight variations in manufacturing can mean that a drive that works perfectly in one Wii might struggle in another without adjustment.
- "New Old Stock" or Refurbished: While your iFixit part is stated as "new," sometimes parts can be "new old stock" (meaning they've been sitting for a while) or even refurbished by the original manufacturer, and calibration can still be an issue.
"Wait a minute... the new DVD drive part came with a new replacement lens didn't it?"
Yes, when you buy a full replacement DVD drive assembly (which the IF207-001-4 is), it absolutely comes with a brand new laser lens pre-installed within the drive mechanism. The issue isn't the absence of a new lens, but its calibration.
What's Happening with Your Dual-Layer Discs:
- Error Message ("An error has occurred"): This indicates the Wii attempted to read the disc, but failed when trying to access data, likely from the second layer.
- Not Recognized: This means the laser can't even properly detect the disc or its format, again, most likely due to an inability to read the dual-layer structure.
Your Options and Next Steps:
- Contact the Repair Person (Most Recommended First Step):
- Explain the exact symptoms: GameCube and single-layer Wii games work, but all dual-layer Wii games fail.
- Inform them that this strongly suggests a laser calibration issue.
- A professional console repair person should have the tools (a multimeter) and knowledge to make this adjustment. It's a common procedure for Wii drive replacements.
- This should ideally be covered under their repair warranty, as the drive isn't fully functional for all intended disc types.
- Laser Lens Calibration (If you're DIY-inclined and comfortable):
- This is delicate and can permanently damage the laser if done incorrectly. Proceed with extreme caution.
- You need a very small Phillips head screwdriver and a multimeter.
- On the laser assembly (the part that moves back and forth), there are usually one or two small potentiometers (tiny screws). You'd typically make very, very minute adjustments (e.g., 1/16th of a turn clockwise for Wii discs, even less for dual-layer).
- The correct way involves measuring the resistance with a multimeter (usually aiming for a specific resistance range, often between 400-600 ohms for Wii lasers, but this varies by lens).
- A search for "Wii DVD drive laser calibration" or "Wii D2B/D2C/D3/D4 laser potentiometer adjustment" on YouTube or repair forums will yield guides. Look for guides specific to the drive model you have.
- However, since you paid a professional, they should handle this.
- Contact iFixit for a Replacement Replacement (Less Likely to Solve It Out-of-the-Box):
- While you could get a replacement drive from iFixit under warranty, there's no guarantee the next drive won't have the exact same calibration issue.
- You'd likely just be getting another drive that also needs calibration, putting you back in the same boat or requiring another trip to the repair person.
- Only pursue this if the repair person refuses to recalibrate or claims they can't.
In summary:
The fact that GameCube and single-layer Wii games work, but dual-layer Wii games don't, points almost definitively to a laser calibration problem on the newly installed drive. Your best course of action is to contact the professional console repair person who installed the drive and explain the specific issue with dual-layer discs. They should be able to recalibrate the laser.
