An old tablet in this time
This tablet dosent turn on
My friend gave me this tablet and sayed this: I charged it like for 8 hours but it doesnt turn on. i think the charger doesnt work.
Add a comment
1 Answer
Chosen Solution
Hi @dragondev
You could always try another known working, compatible USB-C charger and checked if that worked
If the tablet indicates that the battery is charging, then the charger is supplying the correct amount of voltage/current to the tablet.
If the tablet doesn't turn on when the charger is connected after charging the battery for this amount of time, then most likely the battery has failed and will need to be replaced. The charger cannot do both, attempt to charge a faulty battery and run the tablet at the same time.
Here's a video that shows how to replace the battery in the tablet that may help.
Search online for M10 HD Tablet (TB-X505F, TB-X505L, TB-X505) battery to find suppliers that suit you best.
1 Comment:
Today i called my frend and asked if it doesnt turned on and he just put there the wrong charger so sorry for disturbing you
by
Add a comment
Add your answer
Airfix will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 103
