Home Button Stuck After Color Swap
I did a color swap on the iphone 4 and now the home button gets stuck and sometimes its hard to press. Can anyone tell me whats wrong and how i can fix the problem?
Hi Carlos,
Did you also replace the home button when you did the color swap? I suppose...
The home button might not be perfectly (re-)fastened. That means that either the position of the home button or the hole for the home button (i.e. eventually the position of the LCD/Digitizer unit) might have slightly shifted.
I would check out this possibility.
Steffen
Is it possible for the home flex button to not "sit" right...causing it not to work? I've replaced the cable, dock connector and the speaker in hopes that it would work...the home button worked before the color swap. Is there something on the mother board that could be possibly damaged? Thanks!
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 746
