Repair manuals and support for cars and trucks manufactured by Chevrolet.
824 Questions View all
How to replace 2005 Chevy Malibu alternator?
how to replace alternator
Score 1
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
nepplpaul, you forgot to tell us what engine you need the information for. Here is the info for 4 cyl from here:
"Disconnect negative battery cable.
Remove the air cleaner resonator.
Remove the drive belt.
Remove the radiator inlet hose.
Disconnect the engine wiring harness electrical connector from the alternator.
Reposition the engine wiring harness lead rubber boot.
Remove the engine wiring harness terminal lead to alternator nut.
Remove the engine wiring harness terminal from the alternator stud.
Remove the alternator bolts.
Remove the alternator.
You can also get more information from here. Hope this helps, good luck.
Score 3
Add a comment
Add your answer
nepplpaul will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 37
Past 30 Days: 197
All Time: 9,158
