Repair, disassembly, and troubleshooting information for the Xbox Series S, Microsoft's newest small form factor, digital-only gaming console. The Xbox Series S was released alongside its more powerful big brother, the Xbox Series X, on November 10th, 2020.
Mi consola no enciende
My Xbox Series S console was working perfectly until a few weeks ago when I pressed the power button and the white Xbox button lit up for a second and then turned off without showing any image. I've changed power cables, I've changed plugs throughout the house and I've connected it directly to the power supply without a power strip, in addition to waiting a few hours for it to discharge and on top of that it doesn't even open the solver by pressing the sync and power buttons. I've taken it to the technician and it works perfectly for him for hours. I thought the problem is in my house but the voltage is fine and all the appliances work perfectly and a few weeks ago it was working so it doesn't make sense that it's the voltage problem in the house. Can anyone help me? I would really appreciate it. Thanks
Add a comment
1 Answer
Most Helpful Answer
Hi!
Well, to be honest, this is common issue with the Xbox Series.
Usually it's the MOSFET which is failing on the motherboard..
Do you have any soldering experience? This won't be an easy repair.
You can test the PSU first by measuring the voltage. This would be the first step anyway. But, most likely it's the MOSFET.
If you need any guides or more info, please let us know.
Score 1
Add a comment
Add your answer
NETOG BOUKADDUH will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 16
All Time: 109
