Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3236 Questions View all
could this be it?
when i was on my way in after i raised up the mother board a peace of black rubber fall out.
Add a comment
1 Answer
Chosen Solution
If it is long and very thin, it is the rubber cushion which has long slot that sits on edge (top edge) of logic board, precisely under the two screen flex cables. It is a protective device for the cables, though not absolutely necessary, just set it back into place when you put iPhone back together.
Score 1
Comments:
what if the screw is not screw in at all. its the one that hols a panel where all the connections from the LCD and front camera connects.
by
Add a comment
Add your answer
sergeybat will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 213
