Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
357 Questions View all
A1237/A1304 Audio Board Differences
I recently upgraded my A1237 to a A1304 logic board. Everything works fine except for audio. The audio board *is* detected and shows up in the control panel, however no sound output can be heard. I know that one of the speakers is attached directly to the audio board and I've checked all the connections.
In the System Profiler
Device ID: 0x10DECB79
Audio ID: 53
Available Devices:
Headphone:
Connection: 1/8 Inch Jack
Speaker:
Connection: Internal
If someone could compare this info to their true A1304 (Not a frankenstein version like mine) Or someone has also done this swap. I'd greatly appreciate any info.
Comments:
So the original machine was the A1237 (Early 2008 Orig Macbook Air 1,1) and the logicboard swapped in is from a A1304 (Late 2008 Nvidia Macbook Air 2,1) I do not get audio out of the external port either. I'm not sure where I should be looking for a 'red light'. Would this be inside the headphone jack itself (in the IO hatch)? I don't see one on.
by
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
From my initial check, both machines appear to be using the same part but I don't know the exact machines you have. Check to see if it's Apple Part #: 922-8772. Also look in the audio port and see if you have a red light on. Also, do you get sound out of the external audio port?
Score 2
Comments:
by
so the part number *is* 922-8772 anyone else have any input?
by
Add a comment
Add your answer
phadin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,139
