The Xiaomi Redmi 9C is a low-budget smartphone by Xiaomi released June 2020. It has a 6.53" IPS LCD display, a 13 MP main camera, a 5000 mAh battery, and runs on a Helio G35.
Why is my cell phone microphone not working?
when i called there was no sound when i make a call there is no sound on the second device
Add a comment
1 Answer
@baranjay first you want to check your software and a few other common things. Start with restarting your phone and check the app permissions. Make sure that you have all software updated and that the microphone area is clean.
Start your phone in safe mode and see if that allows your mic to work. If so, you know that the issue is related to some 3rd p[art App that blocks the mic. Uninstall those Apps.
If none of that works, you may need to consider replacing it. The mic is soldered to the sub-board (daughterboard/charging board) Since iFixit does not yet have a specific guide for this, use the one from here It is written in Spanish so use a browser that does the translating for you. Replacement boards are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Add a comment
Add your answer
bar anjay will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 20
Past 30 Days: 46
All Time: 198
