15% Off Selected iFixit Tools — Limited Time
The first generation (KJ) Jeep Liberty, a compact 4-door SUV. Sold in both 2WD and 4WD configurations.
I have.No power to all my windows
I have no power to all my windows. All fuses are good.
1 Comment
I'm having this issue too. All the windows won't roll back up. None of the switches work. Already checked the fuse and the relay and both are good. Changed them anyway just to play it safe.
by
Add a comment
Most Helpful Answer
@davidh92819 since you have already checked your fuses and found them to be okay, you will next need to check your power window relay. If the relay is out, you will get no power to the switch. The relay is located in the junction block inside the vehicle. There should be 12 volt at terminal 87.
Here is the Jeep Liberty Power Windws from a Workshop Manual that'll help you to test your power windows.
Score 1
Add a comment
You checked voltage at each window motor? It's possible there is an issue in the switch causing it to not send a signal to the motors.
Add a comment
Add your answer
David H Martinez will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 40
All Time: 453
