Narrow shape (without color) on the paper. It's a mechanical problem
The Brother MFCL8690CDW printer imprints a narrow colorless shape, without color. It is not a problem of color but of some mechanical part that is probably out of place and imprints a shape on the sheet. the image is very clear about it
1 Comment
@clanius let's see if our printer Guru @nick has a solution for you.
by
Add a comment
1 Answer
Chosen Solution
The first thing I always do is a "halfway test," which is when you pull the page before it hits the fuser and make sure the defect isn't imprinted in the fusing stage. If it doesn't occur, the pressure roller in the fuser is shot, or the fuser cover is doing it - this one is extra fun to isolate, given there are two parts that can cause this type of defect on the page, and one of them is tied to the fuser cover assembly. It's worse on these because Brother doesn't consider the fuser replaceable by the user(1), so you can't buy them directly from Brother - you need to take the back panel and a side panel off the printer, locate the P/N, and source it from an outside vendor. These machines are almost always a pain to a degree as well. Here is a link to the parts list to get the search going.
Brother Dcp L8400cdn L8450cdw Mfc L8600cdw L8650cdw L8850cdw L9550cdw Service Manual
Brother Dcp L8400cdn L8450cdw Mfc L8600cdw 8l8650cdw L8850cdw L9550cdw Parts Manual
If the fault occurs at the ITB/drum point, I would look at the meter and roller condition - worn rollers can sometimes do this, even bad separator pads. Check for wear or damage to the supporting parts, such as the metal bar and chassis of the printer. If you can find them cheap enough and hopefully get genuine Brother rollers, I'd try and replace them as a blind luck attempt and see - it may be enough. If it isn't enough, there's a more serious mechanism damage issue somewhere needing heavy disassembly.
Score 2
Add a comment
Add your answer
Clanius will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 118
