pixel 4 very fast drein battery percentage
i have one problem my pixel 4 very fast drein battery percentage. I tried every way to fix the problem, but the problem remained.
11 Comments:
Hi @lashamanch65247
As it is not known what fixes you've tried when you said "...every way to fix the problem,...", please give some examples of what you've already tried.
Did you replace the battery?
Did you try using the phone in safe mode to check if the battery lasted longer?
Did you disable WiFi and BT (if they were enabled) to check if the battery lasted longer?
Did you enable data saver to check if the battery lasted longer?
by
first battery change, next Factor reset, next safe mode. delete all installed apps. turn off Idle lock screen Always show time and info, background process limit No background processes
by
@lashamanch65247
Was it an OEM battery or compatible generic battery?
Has the phone been dropped or gotten wet at all?
by
No dont dropped, no any Physical impact
by
I tested my battery health and show 96%
by
Show 6 more comments
Add a comment
