Everything you need to repair your iPhone yourself! From the newest iPhone 15 lineup, all the way back to the original iPhone 2G released in 2007, iFixit has free repair guides and disassembly information for every single iPhone, as well as the best replacement parts, tools, and tips in the galaxy.
36451 Questions View all
Small portion of the touch screen doesn't work
I just replaced the screen on a 3GS yesterday. Everything works just fine, except there's a capacitative dead zone where the 1 and - keys are. Anyone know what this could possibly be?
1 Comment
I have issue with xs max , touch at screen on Top status bar not work, all function available at status bar not works.
by
Add a comment
1 Answer
Chosen Solution
rsalisbu, it is my experience, that if it is just a certain area of the touch screen that is unresponsive, that it is the digitizer that has failed. In your case, I would contact the vendor and get a replacement. You can also try to see if the same area stays unresponsive when you rotate your phone. If it does it is definitely the digitizer. Hope this helps, good luck.
Score 3
1 Comment:
if it's only on the number screen and nowhere else ie typing or using apps in that area then I'd look at a reboot or resync to see if that helps..otherwise check your connections or do as oldturkey suggests and return to sender.
by
Add a comment
Add your answer
rsalisbu will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 908
