Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1956 Questions View all
Foreign iPhone, still impossible to update software?
My brother bought an iPhone 3GS in Australia, now living in Belgium with it. He's fine with the old OS version, but soon I'm gonna get it and I wanna know if I can update the OS without it getting all blocked and such (We had to jailbreak it to get it to work normally again after an OS update)
Comments:
Is this question not clear? Or does no-one know the answer to this?
current OS is like 3.1 something something. I'd like to get a newer version.
by
never version is 5.1.1 . you are using so old. i want to know the imei of the iphone. go to settings-general-about- imei-? then i tell you about the unlock or lock status thnx
by
on never version you can jailbreak too. you can put the never version apps also
by
I will, just need to get in touch with my brother.
by
Add a comment
Chosen Solution
check out your iphone status on dev.mk about the lock or unlocked status. if your iphone shows unlocked there then you can update your iphone 3gs to latest 5.1.1 . if you iphone is still locked to carrier the you cannot update the phone. if you update it then you have to do alot of things to unlock it . give me imei of you iphone i will check for you or unlock it if possible . thnx
Score 2
Comments:
I've checked the Imei on the site you gave me. It says it's unlocked. If you want to see for yourself: 011982000697116
by
So you have 32gb 3gs black . you can update your iphone to 5.1.1. nothing to worry about
by
you can accept it now thnx
by
So if I update it, do I need to jailbreak it?
Because the iPhone is Australian it blocked up when we updated it with the software from the Belgium store.
by
no need to do anything . just update it. software is same for all the iphones . country doesnot matter for software.
by
Show 1 more comment
Add a comment
what about if it was been updated but the imei was not checked and the phone is stack at restore mode
Add a comment
Add your answer
Ikfixda will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 547
