Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3252 Questions View all
iPhone turns on when plugged into wall then wont hold a charge
Originally my battery went dead so i replaced it. After replacing it I plugged my iPhone into the wall charger, it turned on and eventually says Connect to iTunes. After letting it charge for a while, I disconnected the phone from the wall to plug it into iTunes. Upon disconnecting, the phone shuts off completely and wouldn't turn on. When plugged into mac it will not turn on either.
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
jonscr20, if your iPhone comes on while on an AC charger, but not on your computer, it is most likely that you have a defective battery. Also, check the dock connector for any bend, broken or corroded pins. Clean it with some isopropyl alcohol. Make sure that your USB cable is in good working order. It comes on when charged on AC because of a higher amperage that is supplied by the AC charger. Replace the battery, re-evaluate and, if it still wont work properly, replace the dock connector. Hope this helps, good Luck
Score 2
Comments:
thank you! i just ordered a new battery and ill give it a shot
by
Add a comment
Add your answer
jonscr20 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 702
