Laptop fan Noise and MAYBE dusting or stuck
my laptop's fan makes a loud noise whenever I take the laptop with me . when i hold my laptop the fan seemingly gets stuck on the chassis and im scared that in the future it may get stuck on the operating wires so kindly help with guides Thanks
Add a comment
1 Answer
Hi @jay46531
Here's the maintenance and service guide for the laptop model series.
Go to p.41 to view the procedure to remove the fan.
This will allow you to see what the problem is and also to clean the fan of dust (if necessary) etc.
If the fan is faulty and needs to be replaced, at the top of p.41 you'll find the part numbers for the two fans used in the laptop series. Depending on your particular model specifications, search online for the applicable to your model part number only, to find suppliers that suit you best. Sometimes the part number is printed on the fan itself, if you wish to confirm that you're getting the correct one.
Add a comment
Add your answer
Jay will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 13
All Time: 45
