Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3221 Questions View all
Replaced dock connector, phone still won't charge.
Hi,
I replaced the dock connector in my iPhone 4 today. I closed it all back up and turned it on and the phone still doesn't recognized when it is plugged in. In addition, I placed a call to make sure I had set the microphone back up correctly but it wasn't functioning, and the Home button wasn't responding either.
I watched the how-to video and did the disassembly along with it, but when I perused back over the written one after I found out that the phone still wasn't working, and I realized that they instructed you to take out the camera and remove the logic board, which I did not do. So, I tore the phone apart again, this time taking out the logic board at the appropriate time, removing the new, working dock connector and re-inserting it in the name of being thorough. Unfortunately, I lost a screw and didn't have the time to find it before I had to leave for work, so now I need to order replacements before needing to proceed.
The only other thing of note is that the head of the screw that I removed in step 4 of the ifixit guide came off when I tightened the screw in. I didn't think it was a big deal because the part was held down just fine by the ribbon, and the back plate just held it down more firmly. Maybe I underestimate this issue. Here's the link to Step 4.
iPhone 4 Dock Connector Replacement
For all I know, the phone will work just fine when I do get the screws replaced, but I have a couple of questions.
1) Can someone provide me with a link to a set of iPhone 4 screws? The only thing that I could find was this, but I'm not entirely sure that this is actually what I want, because the listing says "4G" but the description says iPhone 4.
http://www.ebay.com/itm/Replacement-Repa...
2) Can you give me any specific tips on hooking the Home Button ribbon back up? Also, I wasn't sure if the rubber cover for the microphone was put on correctly either.
3) What's my next step if the phone still won't recognize that it's plugged in?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Here are the screws at least.
iPhone 4 Screw Set
iPhone 4/4S Bottom Screws
Hope that helps a bit.
Comments:
The link helped, thank you! Already ordered a set. The urgency of this project just got much less severe, as a replacement iphone 4 just fell into my lap for cheap so I'm no longer phone-less. I've been forced to carry around my iPad to have a music player all week. Talk about a first world problem, huh?
by
Hahaha, yeah man. Sounds super rough. Glad you got an alternative to lessen your plight, though. Not sure I would have survived a full week of that torture.
by
Add a comment
Add your answer
sheamcvaugh will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,698
