AC chargers and battery question.
MacBook Air A1237 with Bulging battery (common Issue)
replaced with battery they claimed was Apple certified.
I only have a MacBook Pro AC adapter-
Q 1- Does the AC adapter/Charger make a difference from one model to the other. Can I use that charger with my Air.
Q2- Battery displays like it is not installed- Everything seem to work fine except removing AC kills system. I am willing to purchase a battery from Ifixit if my mistake of purchasing a 3rd party battery is my issue.
I have reset PMS- It will appear briefly like it recognizes the battery and attempt to calculate remaining life- but then falls back to "no battery available". LED toggles from amber to green like it fully charged.
when battery is recognized- the unit will remain on when AC removed- but not long.
I have read many blogs and info from your site- Big fan/supporter. If this does not solve my issue I now have parts available for this model as well as a Pro A1226
Thanks
Todd
1 Comment
UT- Thanks for the info- This will save me the same frustration. I want to know what OS you Air is running. I assume that when on AC the unit works fine. Does your battery match the old one exactly for Voltage/Wh?
This one may be one for Apple to explain if the Ifixit gang scratch their heads. I am still hunting for a solution.
by Todd
