Why my laptop Stop charging when I turns on the laptop
whenever I turn on my laptop, it stops charging and only charge when the laptop is shutdown.
Add a comment
1 Answer
Hi @anasansari49347,
It may be that the battery has failed and the charger cannot do both, i.e. charge the battery and power the laptop at the same time.
With the charger connected, turn on the laptop and when it has finished booting into Windows etc, create a battery report to check the condition of the battery to see if it OK or not.
When you have the report, compare the Design Capacity value versus the Full Charge Capacity value of the battery as shown in the report. For a good battery the values should be nearly the same.
You can work out the condition of the battery as a percentage by using the formula Full Charge Capacity value x 100 รท Design Capacity value. If the percentage is <35% consider replacing the battery.
If it is determined that the battery needs replacing, here's a video that shows what to do.
The battery model number is L11119-855. This is the HP part number for the battery and is usually printed somewhere on the battery if you wish to confirm that you're ordering the correct one. Search online to find suppliers that suit you best. (suppliers examples only).
Add a comment
Add your answer
Anas Ansari will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 87
