Repair and disassembly information for Google's Pixel 7 smartphone, released in October 2022. Identified by model number GVU6C and GQML3.
Phone worked after battery replacement then suddenly stopped
Hello,
I did the battery replacement of my Pixel 7 and everything looked fine. It powered on and it kept running for quite a bit (around 6h). I put the phone to go through one of the updates and it died.
The phone does not power on. It seems to not be charging and I tried resetting holding buttons and also the find my phone to see if the screen was the issue and nothing.
The old battery was swollen but not fully dead so I tried plugging back again and still no luck.
Any ideas of what I can check? Can I use a multimeter to see if something shortened? I live in a country where Pixel parts are not easy to come about so I am trying everything...
Any ideas are welcome! Thanks!
Add a comment
1 Answer
Since you replaced the battery prior to this issue, I would start by reviewing your work.
It is possible you did not get the battery connector or other connector properly seated.
If it really isn't charging, then it is more likely the battery connector or a connector from the USB port if it is not integral with a PCB.
If it is charging, then maybe another connector.
1 Comment:
Thanks for the comment bill. It seems the connector is fine. I tried both batteries, as mentioned, is there a way to see if the battery is charged? I dont know exactly how to check that.
by
Add a comment
Add your answer
Heraldo Da Silva will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 13
All Time: 165
