How to I fix the stick drift
The stick drift is small but irritating
Hi!
Stick drift can only be repaired by replacing it!
Note, that you do need soldering skills to replace it, it won't be easy.
While you are there, I recommend to replace them for Hall-Effect joysticks straight away when one of them is defective.
Guide: DualSense Joystick Replacement - iFixit Repair Guide
If you need any more information, please let us know!
Contact cleaner. DeOXit is the one I use most often.
You dont need to replace or solder anything. Take the controller down to the point that you can take the sticks off. Pull them off. Blow a quick spritz of deoxit into the middle of each assembly, waggle the stick around a bit, wipe/blow off the excess, and there you go.
I have no idea why everyone seemingly forgot this around 2015 or so. Analog controllers have been the same arrangement of X/Y potentiometers since like 1950 something, they have always gotten dirty, which manifests as "drift", and contact cleaner has always fixed it.
Strip down controller to board. Pull off thumb sticks. Using a screwdriver pop off one potentiometer and bend it out a little. Remove the inner piece. Clean the inner piece and piece you removed with a cotton bud and ipa. Reassemble and repeat for the remaining 3.
Past 24 Hours: 9
Past 7 Days: 79
Past 30 Days: 325
All Time: 674
