Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1392 Questions View all
Does upgrading Wireless Card make AirDrop work?
Does upgrading the new Wireless Card on MacBook Early 2008 make the AirDrop works?
MacBook (Early/Mid 2009) 802.11n Airport Extreme Card Image
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Simply upgrading the wireless card in a device, if possible, makes the feature available. (If you're minded to do this, try to ensure that you choose a replacement that has the same number of antenna connectors as the card that you are replacing.)
In order to use AirDrop, the wireless chip must have the ability to connect to an infrastructure network and be part of a personal area ad-hoc network at the same time.
This is known to be supported out of the box via:
Atheros AR5BHB92
Atheros AR5BXB92
Atheros AR5B93
Atheros AR5BXB112
Broadcom BCM94322HM8L
Broadcom BCM94322MC
With a modified kext, it is possible via:
Atheros AR5B95
Atheros AR5BXB72
Cards that are known to not support AirDrop:
Broadcom BCM94321MC
Broadcom BCM94312MCG
Broadcom BCM94312MCAG
Broadcom BCM94311MCG
Score 2
Add a comment
Add your answer
Sean Foo Kok Keong will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 1,271
