The 7th generation Honda Accord, from 2003-2007.
Why does my car shake when I go 65mph+ but its only when I press gas
My car will shake when i press on the gas going 65+mph but when its below that it has no issues.
Add a comment
1 Answer
Chosen Solution
Hi @yoshiprogaming
Not sure why it is more pronounced when you accelerate but car shaking whilst driving could be due to wheels out of balance or faulty shock absorbers and it can be more noticeable at the higher speeds.
A rough check of the shock absorbers can be done by pressing down hard on one corner of the car and then let it go and then keep repeating this two or three times more in a row to set up a rocking motion in the car.
On the final push let it go and then check if it returns to the normal position with only a single bounce and then stops. If it continues to bounce by itself two or more times the shock absorber on the suspension there, may be faulty.
Do this on every corner of the car.
Another indicator of faulty shock absorbers could be uneven tyre wear
To check if the wheels are balanced, it is best to take the car to a tyre service and get them to check if they are or not.
Score 2
1 Comment:
Mind was a cv axel that was broke. Mine done it between 55 and 65 mph
by
Add a comment
Add your answer
Yoshi pro Gaming will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 24
All Time: 162
