Shop the Holiday Gift Guide
Repair, disassembly, and troubleshooting information for Apple's 7th generation iPad mini tablet, updated in October 2024 with the A17 Pro SoC and Apple Pencil Pro support.
I ruined my charging port. Can’t find a replacement
Does anyone know where I can find a USB-C assembly for this model? It looks similar to the one on the 6 but I have a hunch that it’s not the same. Can anyone verify this or point me towards where I can find a new one? I did find the one on AliExpress but it’s in China and $40. Don’t get me wrong, I’m not being cheap, I just want to verify it’s a unique part before spending more than a few bucks.
1 Comment:
I usually look on ebay with the filter "for parts not working" for the exact item. Occasionally you can get the whole item for less than the price of the part and if something breaks while disassembling/reassembling you'll have the additional part to replace it.
by Share
Add a comment
It should work, usually if the previous generation of the same device has identical dimensions then they change pretty much nothing on the inside, so try swap it and if it doesnt work then return it
Add a comment
Hello Dev, after doing some digging, the 6th gen iPad mini charge port will most likely not work, even though it will likely work, there is a high chance of the port not fitting in the housing as the 2 parts are physically different in their design.
This is the 7th gen port
And this is the 6th gen port
your options are have apple service your device or look harder as there are replacements out there.
Add a comment
Add your answer
Dev will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 53
All Time: 475
