Plugable's USB-C 7-in-1 Multiport Hub is a versatile accessory that expands the connectivity options of USB-C enabled devices, offering seven ports including HDMI, 3 x USB-A, 1 x USB-C for charging, 1 x SD card slot, and 1 x microSD card slot.
Plugable usb-c 7 in 1 hub doesn't working Plugable usb-c 7 in 1 hub do
Score 1
Add a comment
1 Answer
Most hubs need to be directly connected to the system as they do require a bit of power, daisy chaining is not recommended! If the hub offers direct power connection via a power brick then you might be able to. Still I don’t recommended doing that as you also face throughput issues.
Add a comment
Add your answer
Ibrhaim Khan will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 40
All Time: 390
