A television game console produced by Sony Computer Entertainment; the PlayStation 4 Slim (CUH-2000 Series) is a thinner replacement model for the original PS4. Announced September 7, 2016.
The black connector came off the power supply
Black connector came off of ribbon cable and the circuit board. Don't know how to put it back on so the ribbon cable can be put back.
Score 1
Add a comment
1 Answer
Most Helpful Answer
Well, you have managed to dislocate the connector from the circuit board. The connector is fine, but:
A few possible things can happen.
  1. the copper pads come off the PCB.
    1. you can fix this by locating where the copper traces go to, and solder in wires to get an alternative path. This is quite advanced.
  2. the connector separated from the copper on the PCB
    1. You can solder the connector back on. Thsi is also quite advanced, the pad for the connector is likely underneath. Or:
    2. solder ribbon cable to the pads meant for the connector (I have seen manufacturer do this to cheap out)
  3. The connector is a thru-hole component, and you managed to destroy it.
    1. This mostly follows possibility 2. Thru-hole pads are a lot more difficult to destroy, as it anchors into the board itself.
  4. Nothing is permanently damaged, the plastic slip off of the contacts.
    1. This is the best case scenario. You can just carefully push the plastic back to its original place.
Score 1
Add a comment
Add your answer
Sherrie Marsh will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 40
