Comprehensive repair manuals on all portable tablet computers by Apple. Repairs are likely to require heat and careful prying.
3730 Questions View all
iPad for display purpose with a mac mini?
Well my question is can i connect my ipad to the mac mini for using it as a display as well as the ipad's touchscreen for input? I have tried many vnc softwares but none of them are flawless (smooth). Is there a way i could use my iPad for i/o purpose with the mac mini?
Score 1
Comments:
This question was migrated from http://meta.ifixit.com/Answers.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Most Helpful Answer
The problem with using the iPad over VNC is that there's bound to be some lag just by the nature of the problem; getting that much data over wireless isn't easy.
I personally use Air Display to use my iPad as a secondary display to my MacBook when I'm on the go, and it's nice to have the extra pixels, but I generally just use the iPad space for non-moving windows, such as reference materials and such.
To directly answer your question: no, you won't be able to get a smooth 60 Hz experience with an iPad hooked up to your Mini. However, if you're fine with a little delay then Air Display should work well for you - it allows you to use the iPad for mouse and keyboard input, which is pretty nice.
I should note that I haven't done this with the iPad as the sole display -- you will need another display at least for the initial setup.
Hope this helps!
Score 1
Add a comment
Unfortunately, no.
Add a comment
Add your answer
Aditya will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4,740
