The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
I am not able to intall new OS on my MacBook Air 2013 model 6.2
i have USB which i boot using software with Sonoma OS after i installed it i get white background and when i restart my computer the OS is no longer their.
1 Comment
What was the last OS that was installed on the laptop can you remember?
by
Add a comment
1 Answer
Most Helpful Answer
Sorry your system can’t support Sonoma natively, the highest it supports is MacOS 11.x (Big Sur). Using a shim service you can run newer macOS releases, but your hardware now comes into play! If your system only has 4GB of RAM I would stick with Big Sur and call it a day, if your system has 8GB but has a small SSD drive 256GB or less again stick with Big Sur.
If you’ve upgraded the drive you can use OpenCore to run a newer macOS releases, just be careful you aren’t expecting newer features to work that require hardware your system doesn’t offer.
For most this system is just not powerful enough beyond simple web surfing or writing and image processing. It’s not powerful enough for online or down loaded heavy graphics game play.
Score 1
Add a comment
Add your answer
Ibrahim 48 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 34
All Time: 159
