It's powering on but heating food
Score 1
2 Comments:
Hi @peterkiiru
What is the model number of the microwave oven?
by
Se enciende el visor pero los números no funcionan
=== Actualización (06/10/25) ===
No creo que sea eso, por qué todo trabaja muy bien, solo al seleccionar en el tablero los números simplemente no se maracan
by
Add a comment
1 Answer
This is most commonly the result of the magnetron that is no longer functioning.
But there are some other possible components worth inspecting namely the fuse, power diode, capacitor, transformer, etc.
On mine it was just the magnetron connector which had the small rf suppressor capacitor shorted out to ground. A u/s magnetron was obtained from a domestic repair shop and I just swapped connectors (which are cheap to buy) but not so easy to replace.
Please Note: If unfamiliar with electronics/high-power electrics, it is not advisable to fix it yourself. Lethal voltages are involved via the main capacitor and if not properly discharged can cause serious injury or a fatal electric shock.
Therefore, testing of components and experience in component replacement/ modification is a pre-requisit for this kind of diy job.
Add a comment
Add your answer
Peter kiiru will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 372
