2008 netbook; Model ZG5 AOA150-1691; 8.5" screen; 1.6 GHz N270 Intel Atom Processor
74 Questions View all
Where can I download the drivers
where can i download the drivers
Acer Aspire One ZG5
display
ethernet
Score 4
Add a comment
Chosen Solution
Right off Acer's website.... These links should work fine for you.
Display Driver - http://global-download.acer.com/GDFiles/...
LAN - http://global-download.acer.com/GDFiles/...
Wireless LAN (not sure if you meant this) - http://global-download.acer.com/GDFiles/...
Score 3
3 Comments:
do they work with wondows vista
by
Um... no... Acer seems to have only the XP versions... did you put Vista on this machine yourself?
by
yes I need the lan driver, vga display driver
by
Add a comment
Hi Liz,
I have a couple of Acer laptops; (different models just to make things a bit more interesting!) I have always managed to get the driver that I want from the link below.
www.acer.com.au/ac/en/AU/content/home
Hope this is of some use to you?
Cheers Al.
Score 2
Add a comment
Hi, try this:
http://acer.supportscentre.com/driver-of...
1 Comment:
If you do not need Windows operating system, i install Xubuntu from: http://xubuntu.org/
burn it, boot xubuntu cd, choose "TRY Xubuntu" (loading operating system something like Windows Live), connect your internet, and choose install xubuntu now.
Install with all drivers, no need download drivers, all is automatic.
I recommended.
Thank you.
by
Add a comment
You need to go to acer official sites and then you need to click on this link http://www.acer.co.uk/ac/en/GB/content/g....
now you need to select your os type and then will get your drivers.
Else you need to download driver checker on your computer and then you need to run it. once you will run it then it will detect the drivers and download the drivers for you automatically.
Add a comment
Add your answer
LIZ will be eternally grateful.
Past 24 Hours: 8
Past 7 Days: 22
Past 30 Days: 87
All Time: 36,160
