The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
Small Rubber Things (Battery & Heatsink Screw Heads)
Are these things really necessary to put back on?
They are a bit fiddly to put back on...... Other than to show Apple they were removed to void any warranty I can't really see the need for them?
Add a comment
1 Answer
Most Helpful Answer
The CPU heatsink caps should be put back, they are there to protect the system from a loose screw condition that can develop where the heatsink screws walk out of there mount. I’ve seen it twice when the caps weren't installed.
Score 1
1 Comment:
@danj OK I will try to get them back on, looks like they need some type of glue to stick back on, or just use a soft rubber sticky pad to the case above them should do the same trick as they are likely to fall off easily.? What about the battery parts?
by
Add a comment
Add your answer
livfe will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 92
