A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
Unless unplug the power cord and plug it back the PS4 will not display
After shutting it down, if I try to power it back on, the screen won’t show anything and there's no sound. However, I can still turn it off using the controller. So I suspect it might be related to the HDMI connection.
Here’s the interesting part: If I unplug the power cord from the PS4 after it’s turned off and then plug it back in, it usually boots up fine—there's video and sound, everything works as expected.
Any response would be helpful, thanks!
Add a comment
1 Answer
Chosen Solution
Hi @glp28628
Looking at images of the motherboard online it seems that it has a removable coin cell battery on the board.
Most likely it is a cmos battery as what used to be used in laptop PCs
This battery is used to maintain the BIOS when the console is turned off and when its voltage gets too low this can cause the console not to start or to not start properly.
Here's the ifixit PlayStation 4 Motherboard Replacement guide that will help you to remove the motherboard so that you can remove the cmos battery and replace it. Unfortunately it is on the underside of the board, so you will have to remove the board to get to it.
If the battery's voltage is <2.5V DC or if it is >4-5 years old, replace it.
The battery model number will be on the battery. Most probably it's a CR2032 or similar which are available everywhere e.g. supermarkets
Score 1
1 Comment:
Thanks for your reply, I think what you said makes a lot of sense. I didn't realize that every time I plug and unplug the power cable, the system time resets to 1970. I had overlooked that part.
by
Add a comment
Add your answer
glp will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 27
