Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1496 Questions View all
Why is there a "no service" or "sos only" after water damage?
HELP!
I dropped my phone in water today and ive kept it in a bag of rice all day!
Its started working again, full function of my touch screen and eveything else!
But i cannot get any service it just says "sos only" and "searching" sometimes!!
HELP ME!!!!
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
raquel, since your water damage is still recent I strongly suggest that you clean your iPhone. The rice is a great first aid , but it does not clean nor repair your phone. If you do not clean it properly, you might run into corrosion damage later on. First thing you want to do, is to not try to turn your phone on anymore until it is cleaned. If you continue to turn it on, you are running risk of shortening out the logic board and its components. Use this guide to clean your phone. After you cleaned it, replace the battery. Reevaluate for any damage after you do those things. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
raquel will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 12
All Time: 897
