The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
My Xbox 360S Dic Drive automatically open every time I close it
So basically, My Xbox 360s' Disc Drive always open from alone on boot up and when I want to close it it also just opens its self again
Add a comment
1 Answer
Most Helpful Answer
Hi!
Could be multiple things.
1: Please replace the disc drive belt first and see how that goes.
2: if that didn’t worked, take the drive out and clean it completely. Also check if the mechanism is still OK and not misaligned or something.
3: if all above didn’t worked, then you could replace the drive for another one and see if it’s fixed or not (IMPORTANT: you need to transfer over the PCB!)
4: if that didn’t worked, then it’s motherboard related. Please check all the traces if they are OK and make sure that all the capacitors are OK and not leaking.
If you have any questions, let us know!
Score 1
Add a comment
Add your answer
g00dmid will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 28
