Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
830 Questions View all
Why won't my iPod charge or power on?
My Ipod sat around for a couple years in a drawer because I bought an Itouch. My boyfriend would like to use it now, but it will not charge or power on.
Add a comment
1 Answer
Chosen Solution
Jenny, if it worked before and it did not have any issues, I would start by replacing the battery. It most likely has discharged behold the threshold where you can charge it. Here is the guide. Just be careful when you pull up on the battery cable connector. It does have a tendency of breaking of the logic board. I personally use a paperclip bend into an L-Shape and hook it underneath the clip, then pull gently straight up. It is not a complicated thing to do. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
Jenny will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 457
