A television game console produced by Sony Computer Entertainment; the PlayStation 4 Slim (CUH-2000 Series) is a thinner replacement model for the original PS4. Announced September 7, 2016.
PS4 Slim sometimes spins up, but displays "Unrecognized Disk Error"
Recently, Whenever I put a disk in my PS4 Slim, it spins up, stops, click, the disk reset mechanism kicks in, and then it eventually displays "Unrecognized Disk Error".
Is this repairable? Or should I purchase a new drive?
Thanks!
Link to video of the issue - https://youtu.be/LlkQF7MMo0c
Add a comment
Hello, there could be multiple reasons to why the PS4 slim is not detecting your disks, I listed down a few options you could try out before replacing the entire thing:
  • Dirty or Scratched Disc
    • Try multiple discs, including a known working one.
    • Clean the disc with a microfiber cloth and isopropyl alcohol.
  • Dirty or Faulty Laser Lens
    • Solution: Use a cleaning disc or manually clean the laser lens with isopropyl alcohol and a cotton swab.
    • Repair Option: If cleaning doesn’t work, the laser assembly might be failing and need replacement.
  • Faulty Disc Drive Gears or Rollers
    • If the drive clicks and resets, the rollers might be dirty or slipping.
    • Solution: Open the PS4 and clean/lubricate the rollers.
  • Mechanical Failure (Eject Mechanism Issues)
    • If the drive is struggling to grip and spin the disc properly, the motor or gears might be worn out.
    • Solution: Inspect and replace faulty gears or motors.
  • Damaged or Failing Laser Module
    • If the laser is failing, it won’t read any disc.
    • Solution: Replace the Blu-ray laser or the entire disc drive.
Add a comment
Unrecognized disc, After installing lastest System Software version 12.02 ??
If Yes, I got the same problems, unrecognized disc after installing 12.02 system software.
I also found 3 User said unrecognized disc and 1 user unrecognized game digital license.
Add a comment
Add your answer
iKokomo will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 10
All Time: 60
