Swap HD from MacBook to MacBook Pro?
My ancient MacBook is just beat to heck, but the 500 gig hard drive is pretty new and works great. Can I put it into my wife's MacBook Pro (pulling the 100 gig HD)?
MacBook 500 gig HD is:
Intel ICH7-M AHCI
WDC WD 500BEVT000A0RT0
MacBook Pro HD is:
Model: MATSHITADVD-R UJ-857
Revision: HAE4
Would the MAcBook Pro just "up and run" with the other HD?
Thanks!
JAMES
Comments:
You spec'd the DVD drive... are you going to take out the DVD and put in the HD? (you need a kit for that if it would fit) Put the drive in an external case, you can boot to that with an Option-boot at startup. If that's good you can then swap drives and put the Wife's drive in there to use as an external hd/backup whatever.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
You should have no problems switching drives. I would reset the PRAM just in case. Here's how: http://support.apple.com/kb/HT3964 If you need instructions please give us the last three figures of your serial number so we know your exact machine and can get you to the correct guide.
Score 3
Add a comment
Add your answer
troprock will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 484
